Kernel panic because of new SSD?
I have installed a new ADAT 500gb SSD in my girlfriends laptop. On start up I get kernel panics. After about 2 or three reboots I am able to log in. I have changed the flex cable (hard drive cable) twice so this is not the problem. I have emptied out the PRAM, tried smc resets, I am out of ideas. Furthermore I find the battery life is affected negatively. Could someone give me and idea of what to try next?
Thanks
6 Comments
Does this work fine using another drive?
by Cameron
Your systems specs: MacBook Pro 13" 2.9 GHz i7 (Mid-2012)
Your SSD's specs: ADATA SP550
So from the specs your drive should work here.
by Dan
@danj Could it be caused by something corrupt in the bootloader?
by Cameron
@cam2363 - Generally boot-loader issues wouldn't give you panics. A corrupted OS or app are the more likely. The cause could have been a defective drive or drive cable as the hardware level root issue given the fact the drive is spec'ed correctly for this system.
I would get a better idea on what the panic calls are, which is what @soros was aiming for.
The other direction would be just to wipe the drive down and re-install the OS and the Apps carefully to see if a given add-on or app broke things. Sometimes malware or other nasty is the cause so the rebuilding from good known sources for the OS & Apps would clean that up. I would also scan the backup drive before moving anything over from it with a good antivirus / malware / trojan / spyware cleaner(s) as needed for the OS's that are running on the system (MacOS / Windows / Linux) if you have more than one OS.
by Dan
@danj That's sort of what I meant. I was thinking the same thing with the reinstallation of the OS.
by Cameron
Show 1 more comment
