Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
77 Questions View all
Why is it losing power? Where to buy parts?
Craftsman Model 315.172110 jig saw, it's losing power. I ASSUME the brushes need to be replaced. Not having much luck finding replacement brushes online. Anyone know, first, if this is the issue and second, where I can find a brush kit?
1 Comment
Dan Krier describe the "it's losing power" situation a bit better. If the brushes are worn then the jigsaw will not work. Not working means absolutely nothing working.
by
Add a comment
1 Answer
Chosen Solution
Dan Krier, I had the same result as you after doing a good search brushes discontinued and no alternative part listed. If need be, in the past I was able to order similar brush to what I required in a old saw(new brush was a little wider) so all I did was sand it down a bit to fit, reused old holder/spring and it worked very well. Below is a sample of brushes that are available for power tools. etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.ca/s/?ie=UTF8&keyword...
http://ohiocarbon.com/products/power-too...
Score 2
Add a comment
Add your answer
Dan Krier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 89
