Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Headphone jack, vibration, & loud speaker not working?
The loud speaker stopped working , I changed the piece out & it still does not work. A day later the vibration & headphone jack is not working ? But the charging is working. Could it be that the cable is not plugged in correctly or maybe I should replace the whole charging/headphone jack flex ? How can I fix this ?
1 Comment
Hello, i have same problem, no sound no vibration just charging, i tried change charging port but still same problem. HELP me please. Can be this $@$* problem with audio ic?
by
Add a comment
Chosen Solution
It's, yeah..you need a new Lightning dock
iPhone 6s Lightning Connector Assembly Replacement
iPhone 6s Lightning Connector and Headphone Jack
iPhone 6s Lightning Connector and Headphone Jack Image
Product
$19.99
Score 1
Add a comment
replace the charge port that should fix the issue
1 Comment:
I just replaced my flex cable w lighting port and have no sound or vibration but phone now charges
by
Add a comment
Need to ensure if the speaker pins sits without disturbance on the copper pad of the charging /lightning connector assembly itself. This correction also solved issue of vibrator which was not working.
Add a comment
Add your answer
samantha_luvs_you0 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,492
