Why cant I connect to the network especially 4G
My Xiaomi MI4A cannot connect to 4G network.
When i first bought the phone it (4G network) worked perfectly but now it is forever on edge (E). how do I activate 4G network on my Xiaomi MI4A cell phone?
I've turned it on and off many times, I've rebooted it many times too, I've dialed *#*#64663#*#* and it also doesn't work, all in the effort to try and fix my network problem.
Add a comment
1 Answer
Chosen Solution
Are you using a major carrier in your area? If not the carrier may not have access to the towers. As an example AT&T may have a cross-license agreement with Boost Mobile access to their cell tower network as Boost may not have towers around you. This license may have expired.
Using a second phone see if your SIM will work with it.
Its possible the radio circuit within the phone has failed if your SIM works in a second phone correctly.
Score 1
2 Comments:
Thank you very much for taking the time to read and answer my query.
Yes I am using a major carrier in my area soooooooo I think that rules off the carrier not having access to the towers...
When I insert my sim card into another phone it works perfectly fine with a good 4G connection. Perhaps the radio circuit could be fried? But what could cause that? Do you perhaps know of a Xaomi Customer service centre in South Africa? If there is something like that
by
Sorry Kabelo, I'm not sure if this service center is up and running yet but give them a call: Mi - South Africa
by
Add a comment
Add your answer
Kabelo Maboha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,682
