Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
no sound from right speaker and poor sound from left speaker
My right speaker is not putting out sound. The left speaker is working but sounds very tinny. I am guessing the subwoofer is not working either as the sound is so thin. I tried replacing right and left speakers and the subwoofer, but everything is the same. The connections all seemed to be secure.
I don't think it is a software issue. I have tried many things including resetting the SMC and PRAM. The problem is the same whether I boot into OS 10.6.8 or OS 11.
Score 1
Add a comment
1 Answer
The connection of the right speaker is quite tight and tricky. In my experience it can sometimes disconnect when reseating the logic board. All in all, the acoustic performance of this speaker system is lacklustre. It's a fact. I use Bongiovi DPS system wide audio post-processing software to slightly enhance that poor performance. It works well. https://bongiovidps.com There are other alternatives in this space, but I found this working best for me. Hope this helps.
2 Comments:
I tried out Bongiovi DPS. It raises the volume and seems to boost the high end, but still sounds blown out.
by
In the settings panel, there is an option to disable volume boost. Try the different profiles. I found "MacBook Turbo" working for me best.
by
Add a comment
Add your answer
gaijin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 286
