Why it wont turn on
Ibastek ib-lt1256
I was working charge for about 2 days tried to do it again and wouldn't work
Speaker Repair
Ibastek ib-lt1256
Speaker Repair
Winnie Pooh most likely a battery issue or a charging issue. test your AC adapter with a multimeter for proper voltage. Then check your charging port for any debris, broken or bend pins or any other damage. If all that looks good you should consider changing the battery.
Yes ,it is the berry ,like to know where I can purchase one
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 907
3 Comments
Yeah I know the feeling, same problem with mines, what U do did U get it fixed
by Tasha Cherish
Tasha Cherish does not look like Winnie Pooh is coming back here. you do want to tell us what is going on with your speaker and what you have checked. Same speaker?
by oldturkey03
My speaker is not charging properly, it went out one day I was playing it. I cut power off n plug to charge because of a low battery light on and its been charging for days according to the charging light but when i turn it on it goes back out with same light on low battery light. How when Ive been charging it for days which is wayyy pass the 8 hr minimal charging
by Tasha Cherish
