Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone recognized by itunes but wont power on
By mistake my iPhone 6s was dropped into a hot tub for a few seconds. The phone is recognized by itunes and it shows the following message "iPhone 'iPhone' could not be restored. An unknown error occurred (3194)."
The phone does not power on when not plugged in.
I was suspecting a battery problem but I'm not sure.
Add a comment
Chosen Solution
This is one of @refectio 's excellent answers:
Do not put your phone in rice! The rice myth kills too many phones...
The water is inside the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is. So while it ‘’may’’ soak up some water vapour, the real problem is the corrosion that is taking place as the water evaporates. Powering on the phone accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur.
Open your phone and remove the logic board (follow this guide)
Inspect the logic board, especially around the connectors and look for corrosion.
Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
Rinse in alcohol and repeat.
Let it air dry for a day.
Re-assemble and hope for the best.
Use a tool like 3uTools to flash the firmware as it may be corrupted.
You should also consider getting a new battery
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Score 3
1 Comment:
Couldn't have said it better myself!
by
Add a comment
Change battery or u2 ic
Add a comment
Add your answer
Jakob Koblinsky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
