A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
Power button wont function/stuck
Its been like this for some time but now the laptop wont turn on when i press it. The button is not still at all, when you touch it it starts to move around. No matter how hard i press it it wont turn on. i need help
Score 2
4 Comments:
Add your model number so we can look up how your button is attached
by
pst tta 000d007
by
L50-B nnnnvvb
by
Good day
IT THIS SITE IS ACTIVE PELASE EMAIL ME HWO TO FIX MY POWER BUTTON FOR TOSHIBA PROTEGER 930 SERIES THE BUTTON HAS FALLEN INSIDE THE LAP TOP I HAVE OPENED THE LAP TOP AND THE LOCATION OF THE POWER BUTTON IS ON THE LEFT SIDE CAN YOU HELP MY EMAIL IS MLKAPOOR6325@GMAIL.COM THANK YOU
by
Add a comment
We are awaiting the model number of your laptop. Once we have this we can accurately tell you how to replace the power button, or if it is possible.
AB
Update (11/28/2017)
OK dragon: Now with this info we can proceed.
Your laptop has a power button on a separate little pc board. Can you believe it is attached to the hinge.
It is replaceable along with the hinges . There are a few on e-bay for around $30 some from Great Britton. Shipping average is $15 and one dude from the USA to Canada wants $125. Good luck.
The power button like I said is under the lid attached to the right hinge. It has a mechanical actuator that lives just under the lid that presses on the power button. If the hinge is damaged it may be pulling the screws out of the case. This in turn has ruined the micro switch jut below the lid under the actuator for the button. I would say the only way to get it to run is remove the back of the laptop and take a look at the damage. With the back off you can see the hinges, plus start button. With out taking any thing else apart. Assess the damage then before purchasing the parts.
To replace the hinges you have to take it totally apart but can leave the mother board in, cooling , memory, hard drive. But you have to remove the LCD screen as the hinge runs up the top lid under the screen.
Do not be shy find a Philips jewelers screw driver. Do not loose the screws, the back just pries off with a little coaxing, flat blade knife. Easy though do not pry all in one place work around the lid edge.
Have an adventure with it. Good luck.
Alton
1 Comment:
I have a Toshiba satellite L-50B, and my hinges are breaking and most recently my power button got stuck somehow and now I cannot turn my laptop on. Are there keyboard overrides to power on? Any ways you guys could help me?
by
Add a comment
Where is the power switch on a Toshiba flat screen panel TV 50L3400u
Add a comment
Add your answer
dragonpowerking will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 7,360
