Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
What is the result of a striped LCD by itself
What is the result of a striped LCD by itself without any falling elements in the iphone 6s and how to fix solution?
3 Comments
I've tried it by removing the lcd part connector, but the result is still like a shadow and just a little outline
by
Then you will have to replace it as @theimedic said.
by
Is there a solution other than replacing the lcd?
by
Add a comment
Chosen Solution
Remove the display are re-connect it, the display connector may just be partially disconnected.
Score 3
1 Comment:
It's likely broken, I'm guessing pressure damage
by
Add a comment
1 Comment:
Definitely no .No more other thing you can do to remove the issue .You really need to replace it.
by
Add a comment
Add your answer
Rendi Setiawan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 88
