The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
70 Questions View all
Why is my phone overheating?
My pixel XL is overheating. What should I do to prevent this from happening?
Score 3
Add a comment
Most Helpful Answer
Try taking off your phone case. Some cases insulate the phone in a way that makes the phone overheat.
If this doesn't work, try closing apps that are not in use. Also, do not use very intensive apps for large amounts of time.
Finally, if all else fails you might want to replace your battery. There is a guide to learn how to replace your battery on the device page here on iFixit.
Score 3
Add a comment
you should close all your programs when you want to use your mobail phone for the long period
Score 1
Add a comment
Add your answer
Calantha Tu will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 15
All Time: 651
