Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 Questions View all
The digatal display not working
the digatal display isnot working
1 Comment
What brand and model number is your refrigerator?
by
Add a comment
1 Answer
Chosen Solution
Tina Stavinoha, With out knowing the exact make and model, I will give some what generic answer. Info. from link below. If after a power outage, your refrigerator is cooling or not cooling, you will usually need to reset the front display panel. This is to get the panel working again and also to get the refrigerator to begin cooling again if applicable. (See link below) All the below methods and conditions for reset will vary depending on the make and model of your refrigerator. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://removeandreplace.com/2016/02/02/r...
Score 2
Add a comment
Add your answer
Tina Stavinoha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 48
