My car goes off when theres still fuel in the tank
Hello IFIXIT. My name is Peter. Please I'm having trouble with my 2002 jeep grand Cherokee...its generally a cool ride but this problem just sucks. For some time now,.the vehicle just goes off when the fuel level is almost at the reserve point (a bar above the E) then I have to buy fuel in a jerry can and top it up to get moving again. Please what cud be the likely cause of this problem? Hope to hear from you soon. Thanks
1 Comment
But please what would be the easiest and cheapest way to fix a fuel pump sump that isn't deep enough? I had suspected this was the problem
by
Add a comment
1 Answer
Chosen Solution
@dukepetre,Peter, There is a chance that the fuel gage is not registering quite right and fuel tank is pretty much empty or perhaps some one previous to you had the fuel pump changed with aftermarket pump and the replacement pump sump was not quite as long as original. There fore can not reach the lower reserve level in the tank. It is actually always a good idea to run 1/4 tank of fuel in tank to help pump stay submerged in fuel to cool pump, this helps extend the life of a in tank electric fuel pump. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Score 3
1 Comment:
Peter Uwaifo, If you suspect the fuel pump to possibly be too short/sump because of being a off brand/aftermarket, you would have to drop/remove the fuel tank to access in tank pump assy., remove pump assy. and compare the old pump assy. to a new OEM equivalent pump assy.. Remember though it could also be just a faulty sending unit which is part of the pump assy. also if the old pump assy. is identical to new pump assy.. Below I will post a link showing how pump is removed/replaced.
https://www.youtube.com/watch?v=J4jnxfo5...
by
Add a comment
Add your answer
Peter Uwaifo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 59
