Phone keeps searching for WIFI signal
Phone keeps searching for WIFI signal and hangs. I have done hard reset a million times, doesn't get alright with this. Cant even use it now for making or receiving calls or for that matter, can't do any %#*@ thing on the phone.
The phone is acting weird, it performs its own actions and doesn't respond to the specified actions. I have twice factory reset the phone. The problem still persists.
Score 2
1 Comment
The phone acting weird......., is it also because of any virus presence in the phone..... ?
If so, how do you solve this .......?
by
Add a comment
Chosen Solution
Jaya this could be as simple to fix as wiping the cache partition . Old commands can be retained in the cache even with a factory reset and then reinstated with the new fresh edition
press the VOLUME UP + HOME + POWER buttons all the same time and HOLD THEM DOWN. release only the POWER button when the device vibrates. release the other buttons when the ANDROID SYSTEM RECOVERY screen appears. using the VOLUME DOWN / UP buttons to navigate, select WIPE CACHE PARTITION. Its usually at the bottom of the list .
If this brings no Joy then your next solution is to wipe the system and load a new ROM. If wiping the cache doesnt work let use know and we'll guide you through installing a new ROM. Hope this helps
Score 2
1 Comment:
On my Micromax Canvas Gold, couldn't figure out where the Home button is.
Please help.
If it is the middle button with a Home symbol, below on the phone panel, tried the reset as per your instructions, but didn't get to the Android System Recovery screen, phone resumed back to the normal screen.
by
Add a comment
If you have Xfinity saved as a internet connection, consider deleting it. That always gloms into my connection and I can't seem to shake it until I tell my phone to forget the connection. Once I did that everything was fine
Add a comment
Add your answer
Jaya Kummar (JAY) will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 5,846
