Apple SE port damage
What would cause port damage to a Apple SE. Only 18 days old
Water. I would guess water. If it's just the lightning dock/port. You could replace that. If it is water damage, you probably won't be able to get warranty out of it
iPhone SE Lightning Connector Replacement
iPhone SE (1st Gen) Lightning Connector and Headphone Jack
Can't seem to find the water damage guide. They must have done some work to the site
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 132
1 Comment
A bad copy lightning cable or wall charger / car charger. Is it physical damage? I know that if the lightning cable plug is too large it may permanently push the pins down.
Should be covered under warranty hopefully.
by Ben
