Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
could the passcode change when screen is replaced?
Hello
i replaced a screen for my friend , and when i gave it to him it was working perfectly , i told him to check for mic , speaker , front and back cam , and he did that all infront of me and it was all fine
after that he was gone for 10 minutes , and thencame back and told me that when he tried to enter the passcode , the phone showed that the passcode is incorrect
i tried the screen and it was working fine , it didn't press anything outside touch area
and then to convince him i returned the old screen, it was also working fine and he could enter the passcode correctly but the glass was damaged , and the phone also showed that the passcode was incorrect
i told him that he must have changed the code when he was gone , but he said he didn't
so what happened ? is he lying or did i do something wrong ?
thank you
Add a comment
Chosen Solution
@heshama99 replacing the screen will not alter the passcode. Not sure what happened but the problem is definitely not the screen repair.
Score 3
2 Comments:
thanks
he is not convinced and blaming me , i'll show him this post maybe
by
Lol, he forgot his passcode and is pretty much lying to himself. This is not possible. Unless you changed the logic board which takes a long time to do particularly on the 6s.
It has nothing to do with you, some ghosts probably tampered with the software somehow.
by
Add a comment
Is you iPhone's data completed?
If not, maybe someone flash new your iPhone and then set the new screen passcode
Add a comment
I have the same issue, it says the passcode is incorrect and i am million percent sure i am putting the right passcode
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 37
All Time: 1,040
