How to replace Battery Door
How do I replace battery door??
Henry Gill this guide should be pretty identical to your camera. Follow it right up to step 4. You will see a small pin that pushes through some hinges on the battery door, you will have to remove that by pushing it out. Careful!! There should be a small spring on the inside of the door (by the hinges) make sure that you notice the way it is attached.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 3,402
