Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
IR port cable insert to HDD cable bent - intermittent "?" Folder?
Dear all,
I have a MacBook Pro 13" Unibody Mid 2009. I have inserted a OWC Mercury Electra 3G SSD 240 GB in the main drive bay. This only works now since I replaced the HDD cable with a replacement. (I used an earlier drive - same model - in the optical bay previously but it failed and I got this new replacement SSD drive). When I changed the HDD cable over, it was quite hard to insert the IR sensor cable into the plug of the HDD cable. The IR sensor cable may be bent and perhaps the contacts broken. As far as I can see I have not damaged the newly inserted HDD cable, and the SSD has barely been used. System works fine most of the time, but unfortunately I get the "blinking ? folder" symptom from time to time. Does this have anything todo with a short in the IR cable latch or is the cause more likely something else? Kind regards, Paul
Add a comment
1 Answer
Chosen Solution
Replace the cable. Due to the age of the parts for this model now, there is definitely a higher fault rate with the hard drive cables. Buy a new one and you should not have this issue.
Score 4
3 Comments:
Ok, so I might just buy yet another (3rd) cable and replace the (now 2nd) cable with the former. Thanks very much, I appreciate it.
by
Yup probably bad cable. They're cheap and easy to replace so you can easily try a new one to rule out this possibility.
by
@pacz for the older 2009-2010 models, I once had a couple faulty in a row before. Check the part number on the cable too, to make sure you are ordering the correct one. Check your drive on another computer to rule out this being bad, however intermittent issues like this are always a sign of a failing HDD cable
by
Add a comment
Add your answer
Paul Czechowski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 111
