The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Water damaged MacBook Pro 13" early 2015 doesn't work without charger
So I got a MacBook Pro 13" that had a glass of water spilled into it. Found some corrosion on the battery circuit board (the one attached to the battery). Cleaned it up. The computer works fine except that it doesn't work without the magsafe charger. There is an orange light on the magsafe power supply and the battery percentage is stuck on 89%, and indicates charging. But as soon as I remove the magsafe charger the computer shuts down immediately. What can be faulty? The battery itself? Or the magsafe DC-in board?
Update (05/15/2017)
The logic board itself had no corrosion at all. Removed it and checked both sides, it was perfect. There was only corrosion on the battery's circuit board, the one where the battery connector is attached to.
Actually now that I am in OS X it says it isn't charging. Probably bad battery then I guess?
The battery has 89% charge and still the computer shuts down immediately when charger is removed. What would that indicate?
I tried resetting pram and smc. I also tried smc cycle, by holding power button without charger plugged in, for 10 seconds, then connecting charger and holding power button another 10 seconds. Then when I tried turning it on the fans were spinning at 100% and coconut battery didn't report a battery installed. After that I rebooted machine and reset smc again but the problem still persists with 89% charge, like in the image above.
1 Comment
If you look, it says battery failed. Meaning its dead
by
Add a comment
1 Answer
Most Helpful Answer
The battery is failed and needs to be replaced.
MacBook Pro 13" Retina Display Early 2015 Battery Replacement
Thats the guide on how to do it.
MacBook Pro 13" Retina (Early 2015) Battery
That is the part you need.
MacBook Pro 13" Retina (Early 2015) Battery Image
Product
$79.99
Score 2
2 Comments:
Definitely bad battery. To note also, late 2013-2014 A1502 batteries will work fine on this model, even though it uses a different model number. Just in case the 2015 batteries are way more expensive in your area op
by
Check your battery using coconut battery and report back with what your specs are.
http://www.coconut-flavour.com/coconutba...
Once you report back, we can determine what needs to be done from there.
Also, when you cleaned the motherboard, did you remove it and clean both sides?
by
Add a comment
Add your answer
robert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 204
