Have cracked digitizer screen.
I have a Chuwi HI10 Plus 10.8' screen. It feel about 2' onto a soft carpet and the screen now has 2 cracks across the screen and now the touch screen does not work. Chuwi will not respond to any correspondence I have used. I need to replace the screen. Anyone know the manufacturer and part number of this screen and where I can get one?
Thanks!
6 Comments
I have replaced the digitizing screen but the connector clamp that holds the ribbon cable tight in the connector was broken. I have not been able to get the cable to stay in the connector tight enough to work. Anyone know where I can get a replacement connector or know the manufacturer of teh connector? It is an 8 pin connect with .5mm pitch pins. I have found a few on the Digikey site but not completely sure of the fit or if I can get just 1. Thanks!
by Michael Wright
Can you dab some hot glue to hold the cable? Where did you get the parts? I just broke mine. Thanks and good luck.
by Josh Elam
Hey Josh, here is the link to where I purchased mine:
http://www.ebay.com/itm/10-8-inch-Touch-...
Make sure the one you get has the ribbin cable like the one shown in the picture. The first one I got wasn't close.
When you go to replacing the screen, be VERY, VERY careful. As I said in my original post I have had nothing but trouble trying to fir this thing. Right now I am having trouble getting it to boot up. :-(
Good luck if you decide to fix it yourself.
by Michael Wright
Thank you Michael. I bought one from that same seller, but with the exact part number I needed. Similar looking cable to yours with the chip in it, but slightly different. Now waiting on that slow boat....
Hope you get yours sorted.
by Josh Elam
I bought my replacement screen from AliExpress.com It wasn't that expensive and wasn't that difficult to replace. There are YouTube videos that tell you how to replace them. Just be careful and take your time. I have a H10 and an H10plus. Both got the screens cracked and I've had to replace both screens.
by Robert Kellar
Show 1 more comment
