Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
816 Questions View all
No power, dim green/orange on magsafe mbp 13 mid 2012
Hi, i have a mbp 13 that not doing anything, no power, no fan, no battery indicator, i try everything like disconnecting the bat, push the power for xx seconds, i charged the battery in other mbp, put it back and still without respone (only 1 time the magsafe green light got blinking bright but then started to dim and back how it was before)
So i don't know what to do :(
Edit: i was checking some voltages and it doesn't look very good, also some times i can hear a ticking noise coming from the logic and its in the same time that the orange light flicks in the magsafe connector
820-3115-b
PPBUS_G3H, 9.51v
Pp3v42_g3h, 0.11v
Pp5v_s5, 4.92v
Pp5v_s3, 2.66v
Pp3v3_s5, 0v
Pp3v3_s3, 0v
Smc_bc_acok and ADAPTER_SENSE not present
Chgr_acin 0v
I have checked other voltages butni dont have here right now
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
After you charged the battery up in the other machine, did you check it with Coconut Battery or other APP to see how much of a charge it actually has?
http://www.coconut-flavour.com/coconutba...
With the new battery in does the battery test indicator show anything?
Disconnect the battery and Mag-Safe adapter. Then reconnect both and you should get a spontaneous reboot.
Score 2
Comments:
I didn't check with coconut battery but the other mbp was working good with the magsafe disconnected, intry disconectect bat and mag, recinect both and nothing happend, only the dim green/orange light flicking in the magsafe conector, i checked some voltages in the logic and it doesn't look good
820-3115-b
PPBUS_G3H, 9.51v
Pp3v42_g3h, 0.11v
Pp5v_s5, 4.92v
Pp5v_s3, 2.66v
Pp3v3_s5, 0v
Pp3v3_s3, 0v
Not pressent
Chgr_acin 0v
I have checked another voltages but i dont have here now
I don't know where to start
by
That's not supposed to happen. Please give us a complete history of the machine, Spills, repairs, upgrades or other changes. Plus were there any warning symptoms ?
by
I bought with these problem, it says that it was water damage, but i didn't find anything wrong in visual check, but i put the logic in isopropilic alcohol, clean everything, dry and plug.. and thats all the history that i know (sorry for my English)
by
Add a comment
Add your answer
Nicolas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 91
