Spraying water underneath when I hooked it up
Hello, I'm hooking up my Whirlpool Roper washing machine and it started spraying water from the bottom on the floor. Help! ?how can I fix this?
@peterod11, Pete, your model # may help or at least is it top load or front load. Sounds like you may have to disassemble and check for a loose hose connection or damage hose/fill valve or possible pump/hose leak. The links below may help in the disassembly of your machine and find the source of leak. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.appliance-repair-it.com/Whirl...
https://www.repairclinic.com/Video/Video...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 389
1 Comment
Thank you so much! Its a top loading machine.
by Pete
