Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone clicks screen by itself(original screen)
My iPhone randomly starts clicking by itself it's mostly at the same position and it clickes itself repeatingly on the almost same position. I have to lock the phone and then it goes away. It happens randomly over the day without any special reason. Can it be fixed by cleaning the connectors or by changing the whole screen? (Phone fall into the toilett months ago[at least 7-8] but everything ist working perfectly, except this problem - which isn't always)
Add a comment
Chosen Solution
It's clearly been water damaged. As you've let it dry and continued to use it. The display is likely damaged, and you'll have to replace that. While you're at it, you'll want to clean the board for water damage. You may get away with a general cleaning with 90% isopropyl alcohol, and a q tip. But I would recommend bringing it to a board repair shop, that has an ultrasonic bath, and can remove all the shields. You can follow @refectio's guide to get in
Here's a guide for the water damage
Electronics Water Damage
Here's where you can find a new part
iPhone 6 LCD and Digitizer
iPhone 6 LCD and Digitizer Image
Product
$69.99
Score 3
4 Comments:
Wow, I totally missed that last sentence about it falling in the toilet! Thanks iMedic.
by
Meh, @refectio we're stronger together
by
We could be "TheiMinho" or "TheiMedicho" or something like that ;>)
by
Pooh @refectio I like the @TheiMedicho
by
Add a comment
Most Helpful Answer
Chances are it is a bad screen. I would certainly take a look at the connectors though before spending money on a replacement screen. Follow this guide and be careful to disconnect the battery first and keep track of your screws.
Score 3
4 Comments:
Do I need alcohol or distilled water to clean the connectors? Or just try to reconnect them?
by
Sorry, I missed the part about it falling in the toilet (or did you add it later?). Never mind the screen for now, focus on getting the logic board decontaminated like @theimedic suggests.
by
it fell into the toilet months ago - are having this problem for a longer time now
by
That's exactly why you're having this for a longer time now
by
Add a comment
Add your answer
Patrick Kkll will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,222
