Why do can I not remove the keyboard
I have removed the motherboard, fan, heat sink, but I cannot remove the keybaord. No screws hold it to the case and it will not lift out from the front.
There is no HP 15-ay08081nr are you sure this correct? Also, does each keyboard key have a small rim of metal around it? Or are each key basically touching eachother?
If they have a metal rim, the keyboard is pretty much permanetley attached and cant easily be removed.
If they are basically touching. there should be tiny slots around the edges which you pry at those points and the keyboard comes out.
Hope this helps! If it did please hit the accept answer button!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 24
