Water Problem, Can it be fixed?
Hi All,
I have got this Note 3 N9005, a year ago, the screen just went off suddenly, after inspection I found some water in, not knowing when it happened. I took the battery off, dried it with hair dryer, leave it overnight. Next day I put the battery back and switched the phone on, but nothing happened. At that time I had bought another phone. Now I'm in need for it again after my iPhone has been damaged, is there any possibility it can be returned back to live.
Thank you
Add a comment
1 Answer
Chosen Solution
Electronics Water Damage
That would be your best bet. If it doesnt work, then your outta luck.
Samsung Galaxy Note 3 Teardown
That guide will show you how to take it apart.
Hope this helps! If it did please hit the accept answer button!
Score 2
6 Comments:
Thanks Cameron
I have done all the steps, but when I switched the phone on, it seems that it works fine except the screen. It is black, but the touch screen works. So can I take it is a faulty screen?
by
How do you know touch works? And check your connections first. If they are fine, then that might be the way to go
by
I switched the phone on, and from the beeps when pressing the volume up and buttons, I knew it was working, I have put a SIM card and called the number, and when I swapped my finger on the screen, I was able to answer the call, which meant the touch screen worked, but it was pitch-black, and I don't know what does that mean.
by
Did you check your connections
by
I have double checked all the connections and nothing wrong with them.
by
Show 1 more comment
Add a comment
Add your answer
Julan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 78
