The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Questions View all
dropped into water , the mic and speaker and camera don't work
hello
so my galaxy was dropped into water , after that the mobile works except for the microphone , speaker and camera
i tried to replace the speaker with another by replacing the whole frame that the speaker comes within it , but the new speaker didn't work also
does that mean that the ic is damaged ? what else can i try ?
thank you
Add a comment
Chosen Solution
@heshama99 you are not giving us enough information about the water damage. you did not tell us what you did after your phone got submerged. I do hope that you at least performed a basic cleaning. If not then there is a chance you have either corrosion damage or shortened out some IC's/components.
the first thing before you continue with exchanging part is to clean this board. Use these guides to get into your phone. Once you have your circuitboard removed use this guide to clean your phone. It was written for an iPhone but all the steps are still pertinent to your phone as well. You must remove all EMI shields to clean it properly. While you so that check your board for any missing or damaged looking component. Once it is properly cleaned reassemble it and ultimately you will also have to change the battery since it will eventually fail from the water damage. Now after you properly cleaned your phone, you can do a proper troubleshooting.
Since a replacement of the failed components is not changing anything, it stands to reason the the damage is on the motherboard itself.
C8034,C8035,R8011,L8003, and U8003 are the components for the speaker circuitry
Score 2
Add a comment
You should put it in rice for 48 hours
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 3,048
