TV Screen shows program halfway!
What causes my Insignia TV to work like a half screen and the other half has grayish - white bars only no regular programing.full width of of screen with these bars, whats causing the problem.
Add a comment
1 Answer
Chosen Solution
@fixittv331 this is sometimes caused by the flat cable connecting the TCON to the LCD panel coming loose. The area of missing video can be dark or completely white depending on the panel design. It can also be caused by a bad T-con board. you will have to give us your TV model number so we can try and see if there is anything in particular for you to check.
Unplug your set and remove the back of the TV. then take a couple of good pictures and post those with your question. For that use this guide.
Score 1
Add a comment
Add your answer
Steven M. Galajda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 693
