Installed RAM is not fully usable
I upgraded the RAM from 2 GB to 4 GB by adding another 2 GB memory module. But, in system specs it shows as follows: Installed RAM 4.00 GB (2.84 GB usable)
Why is only about half is usable and not full?
Pls help me in fixing this problem
2 Comments
Is this your system: PSLSAA-00L00U - Toshiba Satellite Pro L500 ?
You may need to contact Toshiba to check what is the correct RAM for your system and check the systems firmware.
by
Hi my system is PSLS1A-030002. I have checked with toshiba web site. I says it is upgradable to 8GB. That is we can insert 2 modules of 4GB each
by
Add a comment
Chosen Solution
Depending on the OS your in the right ballpark if you are running 32 bit OS then the most you would get from the memory is 3.3gb and since you have a media accelerator on your graphics card it can use up to 1 gb of your remaining memory dragging your memory down to 2.3 or less when its running full out in a game or heavy video but during a simple task of checking the allotted memory it wont be using that much so theres were you have 2.8 usable at that moment.
Another thing to check is that you matched the memory.The frequency, latency and timing they need to be the same to function properly.
Hope this helps
Score 4
3 Comments:
Hi
I m running 32bit os on 64 bit processor
by
To get the most out of your ram you can upgrade to a 64 bit OS this will give you the full 4gb or ram but you will still loss some to the graphics accelerator
by
@jimfixer - Good Point Jim! Slipped my mind.
by
Add a comment
32-bit something. By something, I mean your OS, chipset, or processor. If any one of those are 32-bit that's the source. If your chipset is 32-bit your out of luck. If your processor is 32-bit, you might be in luck. If your OS is 32-bit, that's easy. What is the model of your processor?
Score 2
5 Comments:
clear as mud . Come on George make it clear and explain ,look up the model show and do a little research . you've got it in you your close to half way there so if you want those votes clean it up
by
@amitbhadania, re-install your OS as 64-bits. Make a backup of your data, get the DVD install disk that came with your laptop, and use it to re-install your OS. There should be instructions to do it in the manual. Hope this helps.
by
Much better worth a vote now
by
@pccheese , besides an automobile, what was the last tech device you purchased with an instruction manual? :-)
by
@avanteguarde
Most. Yes, most. I don't​ buy Apple. Besides, laptops are good about including one, especially older ones.
by
Add a comment
if you are using a 32 bit OS your ram wil be split it only uses half of the space available if yuo upgrade to a 64 bit OS it will use all the space
Add a comment
As mentioned in previous answers, 32-bit os limits to about 3.5~3.7gb RAM.
If you have integrated graphics you also share the main 4gb RAM with the integrated graphics.
If you want to switch to a 64-bit OS, it is actually quite simple.
Download the ISO or create a USB bootable installer from Microsoft for free.
You can use the key that was included with your laptop for activation.
Add a comment
Add your answer
Amit Patel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 7
All Time: 3,371
