Discover repair information including guides and tips for Whirlpool Refrigerators. Our comprehensive resources offer detailed instructions for troubleshooting and fixing common issues in various Whirlpool refrigerator models.
interior light not working
Have a whirlpool refrigerator, that works like new, have a few years but all of sadden upper light on non freeze side stop working, is not the bulb, do not want to trouble shot without some expertise advise, thanks! I now that could be a control board but in that case can you give a ball park price since can live without it the bottom bulb reflects enough to see the interior, MODEL inside said ED22DQ do not now if is the same as the one in the back, thank you again and best regards.
Add a comment
1 Answer
Chosen Solution
@leoh , Leo, To determine if the door light switch is defective first check wires/connections for being loose/damaged/burnt, use a DVOM/multimeter to test switch for continuity. If the light switch does not have continuity, replace it. To determine if the light socket is defective first check wires/connections for being loose/damaged/burnt, use a multimeter to determine if the socket is getting power. If the socket is getting power, but the light bulb does not work, would indicate that the light socket is defective. If the light socket found to be defective, replace it. If bulb/socket/switch are all found to be good, probable board issue. See video repair links below and last link is part's, which you can click on and also see video installation of the part. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.repairclinic.com/vwo1/Video/...
https://www.repairclinic.com/vwo14/Video...
http://www.appliancepartspros.com/search...
Score 1
Add a comment
Add your answer
leo hidalgo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 12,334
