Charger port defective needs replaced
Can I purchase a charger port/ac adapter ....if so where can I get one is there a specific kind I need for my altec Lansing lifejacket 2
Djay Enderton, Looks like it may be a fairly standard micro USB charging port, perhaps when you open the speaker you can match it to a pic.(search micro USB charging port pic's) or if just loose may be soldered back in position. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to a board and the heat generated could cause further damage if not very careful. I will post a link to a couple disassembly vid's. to get you inside the speaker to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board in case you would like to give it a go. If not wanting to do the repair yourself have a good small electronics/computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=ofBQGpna...
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 26
All Time: 9,966
1 Comment
I need volume controler
by Vinod Gill
