Question Closed
Replacing Capacitors
Hello all,
I am replacing 2 bad capacitors in my 17" iMac G5 and was wondering if they have to be the exact 6.3v 1800uf. I read on another site that the volts could be 10v as long as it is a 1800uf. Is this correct? Or should I just stick to the same specs.
Thank you in advance,
Add a comment
Chosen Solution
Hi,
the important spec is the 1800µF. You can use any voltage of 6.3V and above.
Score 2
Add a comment
It is very important to get low ESR replacements
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,078
