Water leaking out around the door
The water is leaking out my washer around the door....can the rubber and the piece of wire be replaced?
@jytete ,Tracy, If the washer is leaking water the front door seal may have a tear or rip allowing water to leak. The door/boot seal can be replaced and is common repair. Video's below will show how seal is replaced. The 3rd link is where the replacement seal can be purchased which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=tbFdTFrB...
Thanks....this is my problem.. I called Sears tech coming tomorrow....
@jytete ,Tracy, thanks for replying back, good luck with your washer.
Tracy my front load washer is having similar problem. Were you able to fix the problem? The problem I am having is...Water is gushing out the door.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 5,253
