The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
699 Questions View all
PS3 Yellow light of death, Do I need a heat gun?
I just have some questions about the Ylod guide and repair kit. My dad is hesitant to buy the kit because he thinks just to use a hair dryer instead of a heat gun. I know it's late, but my PS3 40GB CECHH01 just got the ylod last thanksgiving of 2016, and I've had it since it's release. So do you think that a heat gun is necessary? And for thermal pads, do you remove the old ones before heating the board? Or after heating the board? Plz reply soon, I wanna get back on my PS3 because PS4 is getting boring.
Score 1
Comments:
Hi, I'm about to attempt a repair on my ps3 using a heatgun as this seems the most popular method, my only concern is- what are the chances of any of the circuit board components on the underside coming loose or falling off once the solder melts?
by
Add a comment
1 Answer
Most Helpful Answer
@imlance you should use a heatgun. A hairdryer does not provide enough heat for any solder to liquify (but sometimes it helps to close the gap between the solder bumps and the die. Read more in the latter part of this answer). You can check for a comparison between the two Hair dryer for logic board reflow? First you do need to remember that this will only work if your YLOD is caused by solder fractures and if they are not to extreme. Reflowing any board with a heatgun is not an exact science and as such does have a certain amount of failure. The proper fix for this would most likely be a professional reball with a new IC (unlikely you can find one. Anyhow, the biggest reason for failure to reflow is not enough consistent heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. You also need to make sure that you apply the thermal paste properly etc. Follow the guide from here and keep on trying.
Second remember that there can be multiple causes for the YLOD:
Dead/Disconnected BluRay Drive
Cold-Joint between the CPU/RSX/EE(If your console has one)
Failing Power Supply
Overheating
Corrupted NAND Flash, and multiple others. the use of this may work for a short time but the real reason for this is the design of the IC. It is a flip Chip design which has shown multiple failures for the PS3 as well as Xbox360 which uses the same design for their IC. Here is a very "quick and dirty" explanation of what causes most of the RROD. It is not always a failure of the solder balls which connect the Flip Chip BGA package to the motherboard. It does happen and you can see why [ http://www.bunniestudios.com/blog/?p=223|on here] More commonly however is that the failure is due to the chip design itself.
As you can see the "bumps" are what actually connects the die to the substrate to make the chip complete. If these bumps fail, the die does no longer make contact with the substrate and thus no contact with the circuit board. The chip has failed.
Score 2
Comments:
idk what caused ylod on my ps3, i had my ps3 on for only like 30 minutes, getting it on and playing cod4, until it just shut off on me, and goes appearing the yellow light. Im thinking will just applying new thermal paste and thermal pads fix it? I think my ylod was just caused by overheating. Like i told you, my ps3 cechh01 wasnt even on for about an hour, then it got ylod after playing a match on cod4, and its not a failed power supply either since the fan still works while turning on.
by
Add a comment
Add your answer
Lance Beltrano will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 154
All Time: 2,207
