How can I fix the A/T shift control system? My car keeps slipping
Car keeps slipping and tends to Rev while driving and jerks.. How can I deal with this?
@gabe13 , Gabriel , As a first step check or have checked the transmission fluid level as this could be the issue. If fluid level OK, the car should be scanned for error/trouble codes that may lead directly to necessary repair(engine light does not have to be on for a fault to be stored in the computer). Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. If for some reason the auto parts store could not read/retrieve transmission code, go to a good local tranny shop and have them diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 529
3 Comments
You need to take your car to a transmission shop and have them take a look. I have a 2000 Honda Accord with that problem and the transmission is going to need to be rebuilt, which will cost me about $4500.00. With the slipping, sometimes you can put a chemical for the slipping that helps but where your transmission revs and jerks, it sounds as though you either need to replace or rebuild it.
by nealhatfield
Thank you I'll see what I can do
by Gabriel
Gabriel, the transmissions in this generation of Accord is notorious for the problems you are seeing. Honda didn't provide large enough channels for the transmission fluid to pass through and thus they tend to clog and not shift correctly. Like I said, take it to a professional. While it's true that the auto parts stores can pull the codes for you, they can't do much more in my personal experience. Take it to a transmission shop that you can trust and have them test it.
by nealhatfield
