Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
Why doesn't my trimmer not stay on?
Starts right away but won't stay on for long . Carburetor redone. What can it be? Need some help . Thanks in advance.
Score 1
Add a comment
Chosen Solution
Lisandro Guzman, The spark arrestor is a small screen that prevents the engine from emitting sparks. Over time, the spark arrestor can become clogged with soot/oil build up. If the spark arrestor is clogged, the engine may stall. Remove mufler to access arrestor screen. To unclog the spark arrestor, remove it heat screen with propane torch and clean off ash/residue with a wire brush. You may also replace the spark arrestor. Also look for build up of carbon in the engines exhaust port and carefully scrape port clean(do not let carbon fall in cylinder or could cause damage). Other possibility is fuel cap vent plugged, remove gas cap (careful of fuel spillage) and see if the engine runs better. Carberator out of adjustment and sometimes these small engine carbs. still will not operate after rebuild. Check links below to see how to clean /check spark arraestor screen. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=U0LJ3gX2...
http://www.ereplacementparts.com/article...
https://www.repairclinic.com/vwo14/Repai...
Score 1
Add a comment
Wont stay running cant find gap of spark pug andit got gas and have to pull sting maybe 100 times before it runs
Add a comment
Add your answer
Lisandro Guzman will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 19
All Time: 16,304
