Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
LCD screen replacement putting it back together
Is there suppose to be two parts to the ear speaker rubbers. There is one connected to the proximity sensor and front facing camera ribbon. The other part is connected to the clear tape. I also have a small piece of black rubber not sure where it came from .
Add a comment
1 Answer
Chosen Solution
The front camera has a proximity sensor which has a transparent plastic gasket that sits on the proximity sensor. Beside the proximity sensor which its bent uses the black rubber gasket which I think is on that bottom of the image.
That speaker gasket isn't supposed to be taken off from a old screen. The replacement screen should have the earpiece gasket with adhesive pre-installed, if not then the supplier for that screen is really cheaping out.
Score 3
Add a comment
Add your answer
Ronda Monroe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 66
