My charger is not showing turbo charge when connected to charger .
My Moto g turbo is draining very fast,hardly for 2-3hours after full charge.When connected to charger it does not show turbo charging.I am facing this issue since 4 days.when I opened back cover of my phone it has some sticky moisture type substance.please help what to do.
Score 1
Add a comment
1 Answer
I'm no expert, but it sounds like your battery is reaching the end of it's life. The fast draining is synonymous with a battery that's had too many recharge cycles. The oozing however, I'm not quite sure. Although the phone does not have a removable battery, im sure most tech shops would be able to swap one out if you let them know ahead of time. Or, if you want Motorola to do it, click here -- https://motorola-mobility-en-in.custhelp... -- to get it replaced. Hope this helps!
Add a comment
Add your answer
Faiza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 148
