After replaced pro 4 LCD,won't turn on on battery mode unless plug it
After i replaced a surface pro 4 LCD , won't turn on on battery mode unless plug it.
Before i take off the broken screen the pro was working good only screen was broken, so i shutted down and start working on it , after i take off the old screen i tried to connect the new screen on to try it but no response at all.
it does only work when i plug it by the charger and it does shows me that the battery is 100% full on the screen ?
and also i did put piece of paper between the connects part for the battery and motherboard and it does shows me X on the battery on the screen when i turn it on
but i couldn't solve the problem since 1 week and i'v been searching online but no one had these issue before .
so how can ifixit ??
If you unplug it when its on, does it die instantly?
by Cameron
yes it dies like there is no battery ,,
by Mike ali
Same issue. Putting piece of paper between battery and motherboard reports no battery, to one side reports battery capacity as -1 but centered all correct info is displayed in the battery report but as soon as I unplug it, it just cuts out.
by Robin Wilson
has anyone solved this issue? i just replaced the battery and screen in the SP4 and the system boots up fine (even shows charging) but as soon as i pull the plug... its dead
by Steven Washere
Yes I fixed mine. There are two little diodes on the motherboard under a silver plate (pictured in the most helpful answer).
I measured the resistance of both (with power disconnected) and one resistor showed 1 (which is the default reading) and the other read 230. I guessed that the faulty one must be the one with no resistance (reading 1) so replaced this and it resolved the problem.
It was rather fiddly to solder though but just used the soldering iron and some old solder from the garage so it may have been easier with something more specialised and finer.
As the replaced diode did not lie as flat I stuck a piece of electric tape on the underside of the silver metal cover to ensure it would not make contact.
After re-assembly, the device switched to battery again when unplugged.
Removing the screen, I damaged the WiFi/Bluetooth antenna (as it is glued to the back of it) but used tin foil to replace this and it worked at least as well as it did before and actually think the signal was slightly stronger
by Robin Wilson
