Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
I can't put my battery in correctly
My phone froze after a update so I removed the battery and put it back in and now one of the sides are crooked and I can't put it back
4 Comments:
And it won't turn on
by
Hi ,
Did you put it back in the correct way?
Samsung Galaxy S5 Battery Replacement
Also not sure when you say "....put it back in and now one of the sides are crooked and I can't put it back"
You "put it back in and now you can't put it back" doesn't make sense
by
Hi,
Does the battery look 'swollen'?
Did you have any problems removing it from the phone?
You might have to compare it to a new compatible battery to see if it is distorted in any way.
by
Add a comment
1 Answer
hello, you could tap it into place with a hammer, it worked for me after i found a samsung S4 on the side of the road when i was walking one day
sadly though the back case was missing
Score -1
2 Comments:
The bottom side of the battery is sticking out though
by
Tap it with a hammer! Do you want it to explode!
by
Add a comment
Add your answer
minecraft killer55 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
