The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
Is there a difference between the two WiFi antennas in the Ipad air?
My wifi is not working well so i'm thinking about buying both of the cables. However,i'm not sure weather the left and right antenna are made of the same components
Add a comment
1 Answer
Chosen Solution
There's a left and right
iPad Air Wi-Fi Left Antenna Replacement
iPad Air Wi-Fi Right Antenna Replacement
Yep. They're different
iPad Air, iPad 5, iPad 6, iPad 7 Left Wi-Fi and Bluetooth Antenna
That's weird. Can't find right. You may have to call/email iFixit and get the product code, and search that. I don't know which one you need
iPad Air, iPad 5, iPad 6, iPad 7 Left Wi-Fi and Bluetooth Antenna Image
Product
$19.99
iPad Air Wi-Fi Right Antenna Image
Guide
Difficulty:
Difficult
1 - 2 hours
iPad Air Wi-Fi Left Antenna Image
Guide
Difficulty:
Difficult
Score 5
7 Comments:
Do they contain the same components? Do i need to specifically buy a left antenna and right one? thanks.
by
That's dual band for you: 2.4 and 5GHz.
I would think they are interchangeable as they are technically a piece of wire. Just my opinion.
by
The active antenna part is the same! It's the mounting as the part is not reversible that is why there are two distinct parts.
Over the years antenna & transceiver designs have changed. At one time we had different antenna's for the different frequencies (2.4 GHz/5.0 GHz). Then we had MIMO which was two antennas which need to be the same.
Overtime the transceiver no longer needed separate antennas of the different frequencies so that allowed them to drop the dual antennas for the different frequencies.
It doesn't alter the need for two antennas for MIMO services. Remember not all devices offer MIMO.
by
do you think the wifi antenna for the ipad air 2 will work on the first gen ipad air?
by
Sorry Jason, Sadly it's not that easy! Apple often altered the mechanicals which they did here so the answer is no you need to use the correct part.
by
Show 2 more comments
Add a comment
Add your answer
jason dads will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,625
