Why did washer quit working
Circuit breaker on cord good.Started washing slowed then quit.
@bo17,James, Circuit breaker on cord good, started washing slowed then quit. This sounds like the motor is faulty. You could disassemble the washer and test the motor, check all connections, see if equipped with fuse/breaker or limit switch, etc. when washer is apart. If not comfortable working on electronics take into a good local small electronics/ vacuum repair shop have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,013
6 Comments
@bo17 what model is your washer?
by oldturkey03
014-HG-14141-HR. 3000psi
by James Stewart
How do u remove the on and off switch
by Mike Arellanes
ARKSEN pressure washer
Item no.014-HG-14141 3000psi
by Mike Arellanes
I have the same washer and it also quit on me. I took the unit apart. Cannot locate a fuse or circuit breaker. inside the washer. I even replaced the plug. Unit still not working.
by louie.tribe
Show 1 more comment
