*crackle* *crackle*
4 Questions View all
What 's the kinds of stones I can use and how can I drill it?
the process of friction is not so clear
please increase the length of it make it clear
Score 1
Add a comment
Chosen Solution
@kassab - Starting a fire without a match can be done many ways!
  • Flint and steel which is by far the easiest to carry with you when hiking.
  • Friction using two things that when rubbed at a high speed create heat. Often you don't have the needed parts or a means to create them to do this (which I think was your core question here).
  • Sunlight using a magnifier (to concentrate the light) which can be a lens made from glass or plastic or even use water! Using a sheet of plastic, a broken bottle or, even a shiny metal pan. Dependent on the Sun being available.
  • Chemical which creates a reaction of fire or high heat. Not very practical when lost.
In all of these you still need dry tinder & burnable items for fuel.
Score 1
Add a comment
Take a bleeding heart liberal democrat and rub her up against a Republican. You'll quickly understand the concept of friction. Just ask my currently estranged girl friend if you can get her to shut up long enough to even get a question in..
2 Comments:
Sulphur Dioxide (Brimstone) and you don't want to drill it.
by
Add a comment
I had so many and such large stones in my kidney they drilled on it til it had to be removed!!!! Largest stone was bigger than a lemon .... Thank God they finally took it!!! Lol I wanted to add my thoughts .... Have a great and groovy day!!!
Add a comment
Add your answer
seif kassab will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 390
