Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
My Digitizer Cable is cut in the middle, can I fix it?
Ok so I ordered a white iphone lcd+digitizer, and i put everything in, but the little cut off on the digitizer cable didnt go through the hole fully. I put everything together, and the cable wouldnt reach, I kinda tugged and took it apart, but it kinda ripped or tore, but it is still connected by a small piece. Is there any way I can put it together? Because the lcd works, but the digitizer isnt working. Can I fix it, or put it together?
Score -1
Add a comment
Chosen Solution
Nope, quite unfortunately Apple decided it didn't matter how much money and parts people are gonna waste, the whole digitizer+lcd+glass are one single unit.
Score 2
6 Comments:
absolutely agreed.
by
I did the same so I guess I have to order a new one then.
by
Yes you will. there is no way of fixing it. I know of people that have tried crazy glue etc. but those are really not good solution since they at best are just temporary fixes. Good luck
by
I know dude sucks.... Also @oldturkey03 how does the crazy glue work? Does it work even temporarily?
by
The one I have heard of was a guy who used a strong magnifier to look at both ends of the cable and he glued the frayed ends together, very tedious, but he got it accomplished. I guess what I would do is take a look with a good strong magnifier and see what the ends look like and if you can overlap that a bit to have the contacts meet, at this time you got really nothing to lose....good luck.
by
Show 1 more comment
Add a comment
Could the plastic pieces be soldered together as a way to keep the pieces together and keep conductivity?
1 Comment:
How can you solder plastic?
by
Add a comment
Add your answer
TechTrace will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 16,489
