Repair guides and support for cars and trucks by Ford Motor Company.
1396 Questions View all
Why is there a oil leak comming from in the timing belt
in the timing belt housing, there is oil running down, can you help me stop it from running down
2 Comments
I had this problem and my mechanic found that a bolt at the top of the timing chain cover had backed itself about three quarters out. He tightened the bolt, no more leak. Avoided a major cost.
by
2016 Tacoma was my vehicle.
by
Add a comment
Chosen Solution
mariocaines52 , You did not state your vehicle model,year,engine. So I will post generic answer. It could be a camshaft seal valve cover seal, crank shaft seal, gasket, etc.. If you can not detect the exact area of the leak, then engine will have to be wiped down(cleaned) to find the leak and then properly repaired. It would be wise to have repaired as this may get onto the timing belt causing it to slip, causing catastrophic failure possibly. If you are not into tackling repair your self have a good local auto shop have a look,diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
UPDATE 04/13/2017 2003 Ford Ranger 2.3
Now that I know what the vehicle is, it is probably the valve cover gasket faulty letting oil leak down onto the front of timing chain cover. You can try snugging/tightening up the cover bolts to see if that helps/stops the oil leak as a first step. The changing of the valve cover gasket looks to be a fairly big job for the inexperienced. I did a search and posted links that I thought would help you. I could not find any free manuals, perhaps your local library may have one or you could purchase one. Good luck with your repair.
https://www.youtube.com/watch?v=NvrAsHaR...
http://www.justanswer.com/ford/1jhgx-200...
Score 2
5 Comments:
I believe its the camshaft seal valve cover. can you help me repair it
by
mariocaines52, this is a volunteer site, I will be away for a bit if you give more info. your vehicle make, model, year, engine.etc. I will try to help.
by
its a ford ranger 2003, 4-2, wl,
by
@kingpreacher, mariocaines52, Now that I know what the vehicle is, it is probably the valve cover gasket faulty letting oil leak down onto the front of timing chain cover. You can try snugging/tightening up the cover bolts to see if that helps/stops the oil leak as a first step. The changing of the valve cover gasket looks to be a fairly big job for the inexperienced. I did a search and posted links that I thought would help you. I could not find any free manuals, perhaps your local library may have one or you could purchase one. Good luck with your repair.
by
95 Isuzu pickup 2.3 5 speed.
Have oil in my timing belt. What to do
by
Add a comment
1996 geo tracker automatic it just started leaking today & the fuel filter / fuel lines went right after why did this all happen in one day???
Add a comment
Add your answer
mariocaines52 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 18,166
