The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
It doesn't turn on and there where black lines on the screen what do I
It doesn't run on and when it did it had a black triangle and you couldn't see the numbers
Add a comment
To assess your problem, open up the back and check for the following:
1. It has water damage >>>>> buy a new one, fixing it will cost more.
2. >>>>> It has taken physical damage ( dropping it, sitting on it, etc. ) buy a new one. It will take a fortune to replace the internal components now.
Add a comment
First, check the batteries.
If they are good, probably just get a new one as fixing those can be expensive.
If you want, get a working one off of ebay and if your case looks better, do a part swap to make one good looking and functioning calculator.
Add a comment
Add your answer
Hello will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 288
