Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why is it just showing a black screen after lcd replacement.
After a replacement of an unresponsive screen but still showed everything working the screen is completely black. I had my iphone lcd replaced and it did show at first a dim light on screen when turned on. i tried unplugging the battery then turning it back on but all it shows is a black screen. i know the phone still works because when i plug my phone up i can see a light through the crack on the inside. i think my backlight shortage is out from not unplugging the battery first from removing the four plugs but i need to know what to order to replace it, like a new logic board or backlight screen. :it doesnt show an apple logo when trying to turn on either
Add a comment
Most Helpful Answer
You probably have a defective LCD. Take it back to the person who fixed it (if you didn't do it yourself) and have it replaced under warranty.
If you need to purchase a new one you can find one here: iPhone 6 LCD and Digitizer
iPhone 6 LCD and Digitizer Image
Product
$69.99
Score 2
4 Comments:
I got another apple screen tested to see if it was a defective lcd from a professional and it still showed just the light on the inside when plugged up so thats why i think its a backlight but i dont know what i need for it.
by
Hold a flashlight over the display, if it's the backlight on the display, you'll be able to see the home screen and what not. Pretty sure, if it's the backlight circuit, you won't be able to see any light. If you life up the display you can see the backlight off the side on the back
by
@cvneutron Zieminski! Cool to see you on here!
by
@cvneutron The legend coming through with great insight. Most likely an LCD issue. I agree with @imedic that it could be backlight fuse or coil issue, but that should be covered under a warranty as well
by
Add a comment
Back light ic chip might have been pop if the battery was not unplugged during repair or trace damage from long screw damage. I would clean the connectors and test screen again
1 Comment:
I tried cleaning it, its still just a black screen.
by
Add a comment
This could be a wide range of things from a defective LCD stated to your connector plates on the logic board they are very fragile and if bent will not work properly. My suggestion is if you did this yourself is look at your quality of replacement and that might be your solution and make sure you ordered the right model number a 6 digitizer might not work with a 6s phone and vice versa
Add a comment
Add your answer
bethany huff will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 80
