Not charging and switching
My cell nokia lumia RM-1013 has not charging and switching what ma i do
piosky_69, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down video/guide to get you inside the tablet to check the charge port. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 577
