E90 error on zanussi jetsystem 1400
Hy, i have this error on my washing machine what can i do?
seo_serginho99 , Information collected from links below. Error E90, Probable communication problem between front and main boards, corrosion/loose/wiring faulty, faulty main or user board.
Unplug the washer and remove the top to access control board.
At the front right, hanging down is the main control board, this is attached to the front control board by thin blue wires. Check that these wires aren't damaged or broken. Unplug the blue wires from the main board and plug them back on, do this 3 or 4 times to clean up the contacts, if connector feel loose give the a little squeeze with pliers to tighten them up. Try the machine again.
If still E90, take the facia panel off and do the same with the plug on the user board.
Try the machine again. Check the links below for more info. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
If it still gives E90 it would suggest that one or both boards have gone faulty.
http://www.justanswer.com/uk-appliance/2...
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 942
