Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
New screen = Apple logo Loop of death / Old cracked screen = Okay
Hi I have a cracked display not original which started to be unresponsive at the bottom part of the screen. So I bought the LCD from IfixIt and changed it. But now it loops the start up Apple logo and nothing else. The old screen works okay as before when I change it back. Could there be any issues with the new screen and other parts like the home button, which is not original?
Add a comment
Chosen Solution
Try to disconnect the front cam and proximity flex and start up your iPhone
Score 3
2 Comments:
This is most likely the case if it does the text on the top left of screen or red screen of death flash reboot.
Also OP you can transfer the front camera flex from the old screen to the new replacement screen if the front camera ribbon cable flex assembly is at fault on the preassembled new screen.
by
I changed the new cables to the old ones and now it works :D
by
Add a comment
It could be the screen itself. It could be the home button cable or the home button itself.
And in case you purchased a full assembly with small parts, it could be the front cam assembly as well like Ron Schuts suggested.
Can you isolate by connecting only the two cables: LCD cable and Digitizer cable, and see what happens?
Note that continuous boot looping will eventually corrupt your data permanently.
Save a back-up using your beat-up screen first, then proceed with any testing you want.
Score 2
Add a comment
I haven't had that happen before if might be an idea to contact apple. The only thing i could think of is Apple brought an update being if you had to replace something it had to be from an Apple approved dealer or Apple. But im not sure if you could give more detail i could maybe give you a better answer
Add a comment
Add your answer
Eivindsolberg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 83
