MacBook Pro models with 13" Retina displays manufactured beginning 2012.
4694 Questions View all
Keys not working, where should I look
Our late 2012 Macbook pro suffered some water damage.
Symptoms were keys appeared stuck, and computer only booted in safe mode.
There was minor corrosion on the keyboard connector to the logic board which I have cleaned as well as I can.
On re-assembly everything works fine except for the 'p' key and the caps lock key.
An external USB keyboard works fine.
Can anyone direct me on likely fix - should I replace the top cover with the keys or i/o board etc.
thanks
1 Comment
Thanks for your quick reply.
I had thought as much. I've been looking at replacement keyboard sub assemblies (new) and used upper cases. I'll try one of them, I guess
by
Add a comment
1 Answer
Chosen Solution
Sadly, the keys switch is bad. Not much you can do here but replace the entire keyboard sub assembly. Or, the complete upper case.
Score 1
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 91
