Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Home button unresponsive, no audio output, and unable to charge?
Hello,
I have suddenly found that the home button on my iPhone 3GS is completely unresponsive--I am using Assistive Touch as a replacement. Additionally, audio only plays through headphones (except for ringtones, text-tones, etc.; those do not play at all). Also, my phone has no reaction to being plugged into a charger that has worked for the past several months without fail. It also does not connect to my laptop on iTunes anymore.
I do not see any red indication of water damage, please help of you can. Thank you.
Add a comment
1 Answer
The home button, Speaker, and headphone jack are all connected to that same dock connector inside the device. There could be a possibility that the dock flex may have been damaged, or could be that the flex became disconnected from the main board. I would try to look up the guide on the dissambly of your device and check all your connections or even just replacing the full dock connector and see if this fixes your issue. Good luck .
Add a comment
Add your answer
Tania Haque will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 34
